주요 콘텐츠로 건너뛰기
Nokia 2610 Circuit Board Replacement
필요한 것
  1. Nokia 2610 Circuit Board Replacement, Battery and Sim Card: 1 단계, 이미지 1/3 Nokia 2610 Circuit Board Replacement, Battery and Sim Card: 1 단계, 이미지 2/3 Nokia 2610 Circuit Board Replacement, Battery and Sim Card: 1 단계, 이미지 3/3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Circuit Board Replacement: 2 단계, 이미지 1/3 Nokia 2610 Circuit Board Replacement: 2 단계, 이미지 2/3 Nokia 2610 Circuit Board Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Circuit Board Replacement: 3 단계, 이미지 1/3 Nokia 2610 Circuit Board Replacement: 3 단계, 이미지 2/3 Nokia 2610 Circuit Board Replacement: 3 단계, 이미지 3/3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Circuit Board Replacement, Front Pannel: 4 단계, 이미지 1/2 Nokia 2610 Circuit Board Replacement, Front Pannel: 4 단계, 이미지 2/2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Circuit Board Replacement: 5 단계, 이미지 1/2 Nokia 2610 Circuit Board Replacement: 5 단계, 이미지 2/2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Circuit Board Replacement, Circuit Board: 6 단계, 이미지 1/1
    • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
    • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
  7. Nokia 2610 Circuit Board Replacement: 7 단계, 이미지 1/3 Nokia 2610 Circuit Board Replacement: 7 단계, 이미지 2/3 Nokia 2610 Circuit Board Replacement: 7 단계, 이미지 3/3
    • Lift the circuit board out of the back cover.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Andrew Wood
회원 가입일: 10/05/10
336 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G52
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
This is so cool tom!
Mo Chiggle - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 3,166
