이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
After removal, lower the metal sim card holder into its original position.
Insert the plastic opening tool into the crack between the front and back panels.
Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
Lift the bottom of the front cover away from the phone.
Continue lifting until the top of the front cover is fully removed from the phone.
다른 3명이 해당 안내서를 완성하였습니다.
