주요 콘텐츠로 건너뛰기
Nokia 2610 Keypad Replacement
필요한 것
  1. Nokia 2610 Keypad Replacement, Battery and Sim Card: 1 단계, 이미지 3개 중 1개 Nokia 2610 Keypad Replacement, Battery and Sim Card: 1 단계, 이미지 3개 중 2개 Nokia 2610 Keypad Replacement, Battery and Sim Card: 1 단계, 이미지 3개 중 3개
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Keypad Replacement: 2 단계, 이미지 3개 중 1개 Nokia 2610 Keypad Replacement: 2 단계, 이미지 3개 중 2개 Nokia 2610 Keypad Replacement: 2 단계, 이미지 3개 중 3개
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Keypad Replacement: 3 단계, 이미지 3개 중 1개 Nokia 2610 Keypad Replacement: 3 단계, 이미지 3개 중 2개 Nokia 2610 Keypad Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Keypad Replacement, Front Pannel: 4 단계, 이미지 2개 중 1개 Nokia 2610 Keypad Replacement, Front Pannel: 4 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Keypad Replacement: 5 단계, 이미지 2개 중 1개 Nokia 2610 Keypad Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Keypad Replacement, Keypad: 6 단계, 이미지 2개 중 1개 Nokia 2610 Keypad Replacement, Keypad: 6 단계, 이미지 2개 중 2개
    • Push on the keypad from the exterior of the phone's front cover to separate the keypad from the phone.
결론
작성자
4다른 기여자 명과 함께
Jeff Carter
회원 가입일: 10/05/10
94 평판
안내서 1개를 작성함
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G52
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 10
전체 시간: 2,153
