주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will show you how to replace the LCD screen for the phone.
부품
지정된 부품이 없습니다.
  1. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off. Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone. Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger. After removal, lower the metal sim card holder into its original position. After removal, lower the metal sim card holder into its original position.
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Insert the plastic opening tool into the crack between the front and back panels. Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Lift the bottom of the front cover away from the phone. Continue lifting until the top of the front cover is fully removed from the phone.
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Remove the 4 screws surrounding the screen using the precision T6 screwdriver.
    • Remove the 4 screws surrounding the screen using the precision T6 screwdriver.
  7. Lift the screen away from the phone and circuit board.
    • Lift the screen away from the phone and circuit board.
    • Warning: The screen is attached to the circuit board by a connector on the circuit board, so lift the screen straight up to avoid damage to the connector.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Wood
회원 가입일: 2010년 10월 05일
336 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G52
4 회원들
안내서 12개 작성하였습니다
My Nokia 2610 dates from 2005 (or2006) and its screen was very scratched.
I bought a complete front cover replacement from vmobile.pl who were very efficient.
Andrew Wood’s instructions are crystal clear. The phone is as new now.
Many thanks. Andrew Boxall
Andrew - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 2,885
