주요 콘텐츠로 건너뛰기
Nokia 2610 Speaker Replacement
필요한 것
  1. Nokia 2610 Speaker Replacement, Battery and Sim Card: 1 단계, 이미지 1/3 Nokia 2610 Speaker Replacement, Battery and Sim Card: 1 단계, 이미지 2/3 Nokia 2610 Speaker Replacement, Battery and Sim Card: 1 단계, 이미지 3/3
    • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
  2. Nokia 2610 Speaker Replacement: 2 단계, 이미지 1/3 Nokia 2610 Speaker Replacement: 2 단계, 이미지 2/3 Nokia 2610 Speaker Replacement: 2 단계, 이미지 3/3
    • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
  3. Nokia 2610 Speaker Replacement: 3 단계, 이미지 1/3 Nokia 2610 Speaker Replacement: 3 단계, 이미지 2/3 Nokia 2610 Speaker Replacement: 3 단계, 이미지 3/3
    • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
    • After removal, lower the metal sim card holder into its original position.
  4. Nokia 2610 Speaker Replacement, Front Pannel: 4 단계, 이미지 1/2 Nokia 2610 Speaker Replacement, Front Pannel: 4 단계, 이미지 2/2
    • Insert the plastic opening tool into the crack between the front and back panels.
    • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
  5. Nokia 2610 Speaker Replacement: 5 단계, 이미지 1/2 Nokia 2610 Speaker Replacement: 5 단계, 이미지 2/2
    • Lift the bottom of the front cover away from the phone.
    • Continue lifting until the top of the front cover is fully removed from the phone.
    • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
  6. Nokia 2610 Speaker Replacement, Circuit Board: 6 단계, 이미지 1/1
    • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
    • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
  7. Nokia 2610 Speaker Replacement: 7 단계, 이미지 1/3 Nokia 2610 Speaker Replacement: 7 단계, 이미지 2/3 Nokia 2610 Speaker Replacement: 7 단계, 이미지 3/3
    • Lift the circuit board out of the back cover.
  8. Nokia 2610 Speaker Replacement, Speaker: 8 단계, 이미지 1/3 Nokia 2610 Speaker Replacement, Speaker: 8 단계, 이미지 2/3 Nokia 2610 Speaker Replacement, Speaker: 8 단계, 이미지 3/3
    • Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone.
    • Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Taylor Hinsdale
회원 가입일: 10/05/10
93 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-52, Amido Fall 2010 Cal Poly, Team 7-52, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G52
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 2,648
