이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
NOTE: Keep the screws in a safe place while you continue working.
Remove screws using the same T5 screw bit to release the computer chip from the case
Carefully remove the computer chip and screen out of the black case with your fingers
The screen is attached to the motherboard by an orange ribbon
Carefully detach the ribbon from the motherboard using your fingers
Reattach new screen by connecting the orange ribbon to the computer chip
Snap the front case back in place with the bottom case with your fingers
Locate the four screws that secure the back case to the rest of the phone.
Unscrew all four screws using a "T-5" star shaped screw driver, turning counter-clockwise.
Holding the rear case, applying pressure to the back of the phone near the location of the battery in order to separate the two components.
The antenna is the "L" shaped device located on the top of the phone in between the back case and the board.
You should be able to remove the antenna with minimal effort.
To put in a new antenna, place it in the same location as the old one. There is no need to connect to any hardware on the phone.
To reassemble the device, follow the instructions in reverse order.
When reinstalling the keyboard, make sure it is in the correct position before screwing the case back together.
When reinstalling the battery, make sure the contacts of the battery connect to the contacts on the phone.
The red square in the photo indicates the position of the brass contacts of the battery.
The photo displays the correct orientation of the battery.
