소개
Changing the battery on your phone might be necessary if your battery is no longer holding adequate charge, or is no longer charging with the proper adapter cord.
The steps required to change the battery of a Nokia 2630b are very simple and require no tools or special skills.
Things to remember:
- Always power down the phone prior to removing the battery.
- Replace the battery with the manufacturer suggested battery to avoid damage to the phone.
Follow the steps below to walk you through the replacement of the battery on your Nokia 2630b.
Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
