주요 콘텐츠로 건너뛰기
Nokia 2630b Screen / Front Case Replacement
필요한 것
  1. Nokia 2630b Screen / Front Case Replacement, Battery Case: 1 단계, 이미지 1/2 Nokia 2630b Screen / Front Case Replacement, Battery Case: 1 단계, 이미지 2/2
    • Press each release button on either side of the battery cover and simultaneously remove the battery cover from the phone.
  2. Nokia 2630b Screen / Front Case Replacement: 2 단계, 이미지 1/1
    • Pull the battery out of the phone with your fingers.
  3. Nokia 2630b Screen / Front Case Replacement, Screen / Front Case: 3 단계, 이미지 1/1
    • Remove the two screws on either side of the battery case using the microscrewdriver using the T5 bit
    • The T5 bit has a star shaped end and has "T5" engraved on the side of the bit for easy identification
    • NOTE: Keep the screws in a safe place while you continue working.
  4. Nokia 2630b Screen / Front Case Replacement: 4 단계, 이미지 1/3 Nokia 2630b Screen / Front Case Replacement: 4 단계, 이미지 2/3 Nokia 2630b Screen / Front Case Replacement: 4 단계, 이미지 3/3
    • Separate the front case from the back case using the iPod opener
    • NOTE: The keypad is a loose piece and may fall out
  5. Nokia 2630b Screen / Front Case Replacement: 5 단계, 이미지 1/1
    • Remove screws using the same T5 screw bit to release the computer chip from the case
  6. Nokia 2630b Screen / Front Case Replacement: 6 단계, 이미지 1/1
    • Carefully lift the black frame off the screen with your fingers
  7. Nokia 2630b Screen / Front Case Replacement: 7 단계, 이미지 1/1
    • Carefully remove the computer chip and screen out of the black case with your fingers
  8. Nokia 2630b Screen / Front Case Replacement: 8 단계, 이미지 1/2 Nokia 2630b Screen / Front Case Replacement: 8 단계, 이미지 2/2
    • The screen is attached to the motherboard by an orange ribbon
    • Carefully detach the ribbon from the motherboard using your fingers
  9. Nokia 2630b Screen / Front Case Replacement: 9 단계, 이미지 1/1
    • Reattach new screen by connecting the orange ribbon to the computer chip
  10. Nokia 2630b Screen / Front Case Replacement: 10 단계, 이미지 1/2 Nokia 2630b Screen / Front Case Replacement: 10 단계, 이미지 2/2
    • Place computer chip and screen back into black case
  11. Nokia 2630b Screen / Front Case Replacement: 11 단계, 이미지 1/1
    • Place black frame back over screen
  12. Nokia 2630b Screen / Front Case Replacement: 12 단계, 이미지 1/2 Nokia 2630b Screen / Front Case Replacement: 12 단계, 이미지 2/2
    • Carefully place keypad back in place
  13. Nokia 2630b Screen / Front Case Replacement: 13 단계, 이미지 1/2 Nokia 2630b Screen / Front Case Replacement: 13 단계, 이미지 2/2
    • Snap the front case back in place with the bottom case with your fingers
  14. Nokia 2630b Screen / Front Case Replacement: 14 단계, 이미지 1/1
    • Reassemble screws with microscrewdriver
  15. Nokia 2630b Screen / Front Case Replacement: 15 단계, 이미지 1/1
    • Slide battery back into place
  16. Nokia 2630b Screen / Front Case Replacement: 16 단계, 이미지 1/1
    • Snap battery cover back into place
결론
To reassemble your device, follow these instructions in reverse order. Make sure to snap the new screen / front case securely into place.
Eric
회원 가입일: 04/07/11
51 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-61, Walters Spring 2011 Cal Poly, Team 9-61, Walters Spring 2011 회원
CPSU-WALTERS-S11S9G61
5 회원들
안내서 5개 작성하였습니다
댓글 2개
Great guide :-) I have a Nokia 2630 too and people can no longer hear me on calls, even though I can hear them. Do you know what could be wrong? Do you think this is something I could fix myself? Thanks!
jfg - 답글
You could try getting a neodymium magnet and run it across the earpiece grill. In my father's case, a lot of metal powder was in there, pressing in the speaker membrane; the alternative is cleaning it (which does require opening the phone using Eric's very nice guide). The alternative to those is ordering an earpiece online - but usually those are really bad quality, so trying to fix the original one would be advisable
Darie H -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,796
