주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 2780 Flip Motherboard Replacement
필요한 것
  1. Nokia 2780 Flip Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert an iFixit opening tool into the seam between the back case and the bottom edge of the phone.
    • If possible, use a plastic prying tool instead of a metal one to reduce the risk of damaging delicate internal components like the battery or motherboard.
  2. Nokia 2780 Flip Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the opening tool or spudger around the edge of the phone to release the clips securing the bottom case.
    • Gently pry the bottom case from the phone to remove it.
  3. Nokia 2780 Flip Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Nokia 2780 Flip Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the battery up and out of the compartment.
    • Ensure the replacement battery is a “HE402 1450mAh 3.85V 5.58WH” Li-ion battery.
  4. Nokia 2780 Flip Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 Nokia 2780 Flip Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • Use a Torx T5 screwdriver to remove the six visible 1.4 mm screws that secure the internal rear housing.
  5. Nokia 2780 Flip Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Nokia 2780 Flip Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool in the seam between the top case and midframe and slide it around the perimeter to release the clips holding them together.
    • Remove the midframe from the phone.
  6. Nokia 2780 Flip Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Nokia 2780 Flip Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Place a spudger or an opening tool under the edge of the press connector and pry straight up to disconnect it.
    • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
    • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  7. Nokia 2780 Flip Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Nokia 2780 Flip Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the plastic cover on top of the hinge.
  8. Nokia 2780 Flip Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Nokia 2780 Flip Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Nokia 2780 Flip Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Pull back the frame surrounding the motherboard from both sides and gently remove the motherboard.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
작성자
1다른 기여자 명과 함께
Miranda
회원 가입일: 03/09/26
217 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 16
지난 30일: 40
전체 시간: 70
