주요 콘텐츠로 건너뛰기
Nokia 3.1 Battery Replacement
필요한 것
  1. Nokia 3.1 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • First, remove the SIM and SD card trays.
  2. Nokia 3.1 Battery Replacement, Open the back cover: 2 단계, 이미지 3개 중 1개 Nokia 3.1 Battery Replacement, Open the back cover: 2 단계, 이미지 3개 중 2개 Nokia 3.1 Battery Replacement, Open the back cover: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Try to use a thin tool like a razor blade to start to pry open the back cover.
    • When you opened it up just a little bit put a plastic card or a plastic opening tool inside the gap.
    • Using the plastic tool slowly make your way around the back cover. You can also use a guitar pick or similar.
    • Hint: the back cover is attached to the body with several plastic noses as well as a thin strip of adhesive. The cover is quite flexible and sturdy.
  3. Nokia 3.1 Battery Replacement, Remove logic board cover: 3 단계, 이미지 2개 중 1개 Nokia 3.1 Battery Replacement, Remove logic board cover: 3 단계, 이미지 2개 중 2개
    • Remove the seven Torx T5 screws from the logic board cover.
    • Remove the logic board cover.
    • Lift up the battery connector from the logic board.
  4. Nokia 3.1 Battery Replacement, Remove battery adhesive strips: 4 단계, 이미지 2개 중 1개 Nokia 3.1 Battery Replacement, Remove battery adhesive strips: 4 단계, 이미지 2개 중 2개
    • At the bottom end of the battery you will see two black ends of adhesive strips showing up from underneath the battery.
    • Slowly pull at those adhesive strip ends to be able to lift out the battery.
결론
To reassemble your device, follow these instructions in reverse order. Also don’t forget some double-faced adhesive tape to fixate the new battery.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Baschtl
회원 가입일: 12/02/12
1,608 평판
안내서 5개를 작성함
댓글 한 개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 33
전체 시간: 7,618
