주요 콘텐츠로 건너뛰기
Nokia 3120 Keypad Replacement
  1. Nokia 3120 Keypad Replacement, Battery Installation: 1 단계, 이미지 1/3 Nokia 3120 Keypad Replacement, Battery Installation: 1 단계, 이미지 2/3 Nokia 3120 Keypad Replacement, Battery Installation: 1 단계, 이미지 3/3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Keypad Replacement: 2 단계, 이미지 1/1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Keypad Replacement, Face Plate: 3 단계, 이미지 1/3 Nokia 3120 Keypad Replacement, Face Plate: 3 단계, 이미지 2/3 Nokia 3120 Keypad Replacement, Face Plate: 3 단계, 이미지 3/3
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Keypad Replacement, Keypad: 4 단계, 이미지 1/1
    • Once the cover plate has been removed, the existing keypad should be easily removed.
    • To install a new keypad, simply place the new keypad in the same place where the old keypad was.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Pierre Tong
회원 가입일: 03/11/13
77 평판
안내서 4개 작성하였습니다
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 회원
CLEM-BENSON-S13S13G2
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 734
