주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 3120 Liquid Crystal Display (LCD) Replacement
필요한 것
  1. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: 1 단계, 이미지 3개 중 1개 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: 1 단계, 이미지 3개 중 2개 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Battery Installation: 1 단계, 이미지 3개 중 3개
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 2 단계, 이미지 1개 중 1개
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: 3 단계, 이미지 3개 중 1개 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: 3 단계, 이미지 3개 중 2개 Nokia 3120 Liquid Crystal Display (LCD) Replacement, Face Plate: 3 단계, 이미지 3개 중 3개
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. Nokia 3120 Liquid Crystal Display (LCD) Replacement, Liquid Crystal Display (LCD): 4 단계, 이미지 1개 중 1개
    • Once the cover plate has been removed, the keypad should easily pop out.
  5. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 5 단계, 이미지 2개 중 1개 Nokia 3120 Liquid Crystal Display (LCD) Replacement: 5 단계, 이미지 2개 중 2개
    • Using a screwdriver, remove the 6, 7 mm Torx-head screws on the front of the phone.
  6. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 6 단계, 이미지 1개 중 1개
    • Once the screws have been removed, the front plate of the phone should be removed, exposing the inside electronic components of the phone.
  7. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 7 단계, 이미지 1개 중 1개
    • Take out the cell phone electronic board
  8. Nokia 3120 Liquid Crystal Display (LCD) Replacement: 8 단계, 이미지 1개 중 1개
    • The LCD screen can now be removed from the body of the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Pierre Tong
회원 가입일: 03/11/13
92 평판
안내서 4개를 작성함
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 회원
CLEM-BENSON-S13S13G2
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 11
지난 30일: 38
전체 시간: 1,698
