소개
The LCD is difficult to get to and the guide requires a moderate amount of work. Tiny parts require patience during disassembly.
필요한 것
Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Using your fingernails or another tool, pry the front face plate out along its edges and corners.
Once the cover plate has been removed, the keypad should easily pop out.
다른 2명이 해당 안내서를 완성하였습니다.
