소개
The SIM card is used to store information and it is well hidden under the battery. It is very easy to open once you know where it is.
도구
부품
지정된 부품이 없습니다.
Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
다른 3명이 해당 안내서를 완성하였습니다.
