주요 콘텐츠로 건너뛰기
Nokia 3120 SIM Card Replacement
필요한 것
  1. Nokia 3120 SIM Card Replacement, Battery Installation: 1 단계, 이미지 1/3 Nokia 3120 SIM Card Replacement, Battery Installation: 1 단계, 이미지 2/3 Nokia 3120 SIM Card Replacement, Battery Installation: 1 단계, 이미지 3/3
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Nokia 3120 SIM Card Replacement: 2 단계, 이미지 1/1
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Nokia 3120 SIM Card Replacement, SIM Card: 3 단계, 이미지 1/1
    • Once the battery is removed, the SIM card compartment will be exposed. Pry the compartment open as seen in the figure. This can be done using your fingernail or a prying mechanism.
  4. Nokia 3120 SIM Card Replacement: 4 단계, 이미지 1/1
    • Once the SIM card compartment has been opened, insert the SIM card into the slot provided on the left side.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Justin Emerson
회원 가입일: 03/11/13
163 평판
안내서 2개 작성하였습니다
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 회원
CLEM-BENSON-S13S13G2
3 회원들
안내서 14개 작성하였습니다
댓글 한 개
Thanks , appreciated.
Ian McCully - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 5,417
