소개
This guide will disassemble the phone's cover plate and key pad to reveal the interface in order to work on the phone's speaker. This guide requires a moderate amount of work as the small parts are tricky to remove.
부품
지정된 부품이 없습니다.
  1. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone. Remove the back cover plate of the phone.  To do this press down the lock as you slide the cover toward the bottom of the phone.
    • Remove the back cover plate of the phone. To do this press down the lock as you slide the cover toward the bottom of the phone.
  2. Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out.  This can be done with your finger-nail or a prying tool.
    • Once the back cover plate is removed, the battery should be exposed. Remove the battery by prying it out. This can be done with your finger-nail or a prying tool.
  3. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners. Using your fingernails or another tool, pry the front face plate out along its edges and corners.
    • Using your fingernails or another tool, pry the front face plate out along its edges and corners.
  4. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  5. Once the cover plate has been removed, the existing keypad should be easily removed. Once the cover plate has been removed, the existing keypad should be easily removed.
    • Once the cover plate has been removed, the existing keypad should be easily removed.
  6. Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone. Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
    • Once the keypad has been removed, unscrew the 6 exposed screws on the front of the phone.
  7. Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
    • Once all the screws have been removed, the front part of the phone should be removable from the rest of the phone.
  8. To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
    • To remove the speaker from the phone, take a pencil or sharp object and poke the speaker free from the removed front part of the phone.
    • To install a new speaker, simply place a new speaker in the same location and put the phone back together.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Pierre Tong
회원 가입일: 2013년 03월 11일
53 Reputation
안내서 4개 작성하였습니다
Clemson, Team 13-2, Benson Spring 2013 Clemson, Team 13-2, Benson Spring 2013 회원
CLEM-BENSON-S13S13G2
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 916
