주요 콘텐츠로 건너뛰기
Nokia 3300B Keyboard Replacement.
  1. Nokia 3300B Keyboard Replacement., Battery: 1 단계, 이미지 1/2 Nokia 3300B Keyboard Replacement., Battery: 1 단계, 이미지 2/2
    • Flip the Nokia 3300B over with the back-side facing towards you.
    • Gently press the button on the back of the battery cover to release the cover and slide up.
  2. Nokia 3300B Keyboard Replacement.: 2 단계, 이미지 1/2 Nokia 3300B Keyboard Replacement.: 2 단계, 이미지 2/2
    • Lift the battery out of the back of the phone.
    • It is easiest to lift the battery out of the phone from the right-hand side, as seen in the picture.
  3. Nokia 3300B Keyboard Replacement., Keyboard: 3 단계, 이미지 1/2 Nokia 3300B Keyboard Replacement., Keyboard: 3 단계, 이미지 2/2
    • Gently push the blue tabs on the top of the phone out of their slots.
    • With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
    • Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
  4. Nokia 3300B Keyboard Replacement.: 4 단계, 이미지 1/1
    • With the screen still facing you, lift and remove the blue faceplate.
  5. Nokia 3300B Keyboard Replacement.: 5 단계, 이미지 1/1
    • Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
    • If you encounter resistance while removing the keypad, be sure to lift up evenly on both sides to ensure that the pins do not snap.
    • When replacing the keypad, make sure that the plastic pegs all enter their proper holes.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Chris Colwell
회원 가입일: 04/13/10
107 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-65, Johann Spring 2010 Cal Poly, Team 18-65, Johann Spring 2010 회원
CPSU-JOHANN-S10S18G65
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 2,782
