이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the Nokia 3300B over with the back-side facing towards you.
Gently press the button on the back of the battery cover to release the cover and slide up.
이 단계에 사용된 도구:Tweezers$4.99-
Gently push the blue tabs on the top of the phone out of their slots.
With the phone facing up, pop the blue faceplate off by using your fingernail (or some tweezers) and working your way around the phone.
Note: If the blue cover does not detach easily use your finger nails to try and split it open, as seen in the picture.
Grab the sides of the keypad and lift each side up vertically, until the keypad is completely removed.
Pull up on the front case containing the screen to separate it from the rest of the phone.
Gently lift the main board out of the back case.
다른 3명이 해당 안내서를 완성하였습니다.
