주요 콘텐츠로 건너뛰기
Nokia 3310 3G Keyboard Replacement
필요한 것
  1. Nokia 3310 3G Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nokia 3310 3G Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
  2. Nokia 3310 3G Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Nokia 3310 3G Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • There is a molded notch in the white frame of the phone near the top right of the battery. Using either a finger or a plastic opening tool, utilize the notch to lift up on the battery, and remove it from the device.
    • This specific device did not come with a battery.
  3. Nokia 3310 3G Keyboard Replacement, Frame: 3 단계, 이미지 3개 중 1개 Nokia 3310 3G Keyboard Replacement, Frame: 3 단계, 이미지 3개 중 2개 Nokia 3310 3G Keyboard Replacement, Frame: 3 단계, 이미지 3개 중 3개
    • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
    • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  4. Nokia 3310 3G Keyboard Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Nokia 3310 3G Keyboard Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Nokia 3310 3G Keyboard Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
  5. Nokia 3310 3G Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 1개 Nokia 3310 3G Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 2개 Nokia 3310 3G Keyboard Replacement, Keyboard: 5 단계, 이미지 3개 중 3개
    • Using a spudger, unclip the bottom left snap to unplug the keyboard. The image shows the motherboard rotated 90 degrees counterclockwise
  6. Nokia 3310 3G Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Using your thumb, push the tab on the right side of the motherboard over to the right and then push downward to unclip the keyboard. It should fall away.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Aaron LeBlanc
회원 가입일: 10/24/18
753 평판
안내서 5개를 작성함
UMass Dartmouth, Team S3-G3, Peak Fall 2018 UMass Dartmouth, Team S3-G3, Peak Fall 2018 회원
UMASSD-PEAK-F18S3G3
3 회원들
안내서 16개를 작성함
1가이드 댓글
Very useful and to the point
OrangeShoe - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 43
전체 시간: 2,847
