이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the frame of your Nokia 3310 3G is cracked or damaged, this guide will help you replace it.
필요한 것
Using the thumbtab molded on the bottom of the phone, pry the back cover off using either a fingernail or a plastic opening tool.
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Use a spudger to simultaneously leverage the shell away and the motherboard up from the body of the shell.
Using a metal spudger, lodge the tip underneath the speaker and between the soft foam surrounding the screen.
Use the metal spudger to leverage out the speaker.
다른 7명이 해당 안내서를 완성하였습니다.
