주요 콘텐츠로 건너뛰기
Nokia 3360 Cover Plate Replacement
  1. Nokia 3360 Cover Plate Replacement, Battery: 1 단계, 이미지 1/1
    • Press down on the back of the phone with your thumb. Then slide the back plate upward toward the top of the phone.
    • Lift the back plate off the phone.
  2. Nokia 3360 Cover Plate Replacement: 2 단계, 이미지 1/2 Nokia 3360 Cover Plate Replacement: 2 단계, 이미지 2/2
    • To release the battery, press the two tabs that are located directly above the battery towards the top of the phone at the same time.
  3. Nokia 3360 Cover Plate Replacement: 3 단계, 이미지 1/2 Nokia 3360 Cover Plate Replacement: 3 단계, 이미지 2/2
    • Lift the battery out of the phone.
    • Note: Upon reassembly of the phone refer to second picture. The bottom of the battery with three square openings should line up with the prongs sticking out of the phone.
  4. Nokia 3360 Cover Plate Replacement, Cover Plate: 4 단계, 이미지 1/2 Nokia 3360 Cover Plate Replacement, Cover Plate: 4 단계, 이미지 2/2
    • Use finger nails of your thumbs to gently pull apart the face plate.
    • While the face plate is pulled apart, use index fingers to pull inner case towards you.
    • Separate faceplate and inner case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kirk Gonzalez
회원 가입일: 01/22/10
223 평판
안내서 3개 작성하였습니다
Cal Poly, Team 8-39, Regan Winter 2010 Cal Poly, Team 8-39, Regan Winter 2010 회원
CPSU-REGAN-W10S8G39
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 2,700
