주요 콘텐츠로 건너뛰기
Nokia 5310b XpressMusic Motherboard Replacement
필요한 것
  1. Nokia 5310b XpressMusic Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 3 단계, 이미지 3개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 3 단계, 이미지 3개 중 2개 Nokia 5310b XpressMusic Motherboard Replacement, Keypad: 3 단계, 이미지 3개 중 3개
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
  4. Nokia 5310b XpressMusic Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic Motherboard Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic Motherboard Replacement: 6 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 6 단계, 이미지 2개 중 2개
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Nokia 5310b XpressMusic Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Max Kirby
회원 가입일: 05/01/11
518 평판
안내서 4개를 작성함
Cal Poly, Team 15-14, Regan Spring 2011 Cal Poly, Team 15-14, Regan Spring 2011 회원
CPSU-REGAN-S11S15G14
3 회원들
안내서 8개를 작성함
댓글 한 개
Step 5 and 6 must be performed before step 3, otherwise, you will dislodge the thread from the front plate. so you have to remove the camera cover first, remove the 2 screws then you can remove the front plate without breaking anything.
Vincent Tschanz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 15
전체 시간: 6,973
