주요 콘텐츠로 건너뛰기
Nokia 6 Home Button Assembly Replacement
필요한 것
  1. Nokia 6 Home Button Assembly Replacement, Display Assembly: 1 단계, 이미지 1/3 Nokia 6 Home Button Assembly Replacement, Display Assembly: 1 단계, 이미지 2/3 Nokia 6 Home Button Assembly Replacement, Display Assembly: 1 단계, 이미지 3/3
    • Power off your Nokia 6 before beginning disassembly.
    • Insert the SIM card ejection tool into the hole on the left side of the phone.
    • Remove the SIM card and microSD card.
  2. Nokia 6 Home Button Assembly Replacement: 2 단계, 이미지 1/1
    • If your display glass is cracked, take precaution by taping over the display to prevent further breakage and harm.
    • Lay overlapping strips of clear packing tape over the Nokia 6's display until the whole screen is covered.
  3. Nokia 6 Home Button Assembly Replacement: 3 단계, 이미지 1/1
    • To soften the adhesive, use a heat gun and heat one edge of the phone for five minutes.
    • To use the heat gun, plug it into an outlet.
    • When the heat gun is plugged in, the heat gun automatically turns on and will start blowing hot air.
  4. Nokia 6 Home Button Assembly Replacement: 4 단계, 이미지 1/1
    • Take a Jimmy and slide it under the glass after the adhesive has been softened.
    • Place a pick under the glass after lifting with the pry tool so that the screen won't re-adhere to the frame again.
    • Make sure to not touch the LCD edge underneath the glass layer with the metal pry tool or the cards. This can damage the ribbon cables underneath and compromise the structural integrity of the phone itself.
    • The corners of the screen are the most fragile part of the screen. Make sure that the entire edge of the screen is dislodged from the frame before prying at the corners.
  5. Nokia 6 Home Button Assembly Replacement: 5 단계, 이미지 1/1
    • Lift the screen off of the phone.
  6. Nokia 6 Home Button Assembly Replacement: 6 단계, 이미지 1/2 Nokia 6 Home Button Assembly Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #000 screwdriver to remove the 1 mm x 1.4 mm screw holding down the metal bracket over the screen ribbon connector.
  7. Nokia 6 Home Button Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the metal bracket with a tweezer.
  8. Nokia 6 Home Button Assembly Replacement: 8 단계, 이미지 1/1
    • Use a spudger to disconnect the screen ribbon connector and free the display assembly.
    • The corners and edge of the LCD are fragile. Be careful attaching it to the back of the phone.
    • Carefully remove the screen from the device.
  9. Nokia 6 Home Button Assembly Replacement, Home Button Assembly: 9 단계, 이미지 1/1
    • Disconnect the battery connector with a spudger.
  10. Nokia 6 Home Button Assembly Replacement: 10 단계, 이미지 1/2 Nokia 6 Home Button Assembly Replacement: 10 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the 1.2 mm x 2.2 mm screw in the upper hand corner of the phone.
    • Use tweezers to remove the bracket.
  11. Nokia 6 Home Button Assembly Replacement: 11 단계, 이미지 1/2 Nokia 6 Home Button Assembly Replacement: 11 단계, 이미지 2/2
    • Detach the cable with the black nylon spudger.
    • Detach the home button and remove it from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chrissy Robins
회원 가입일: 04/15/19
1,510 평판
안내서 10개 작성하였습니다
Cal Poly, Team S9-G15, Maness Spring 2019 Cal Poly, Team S9-G15, Maness Spring 2019 회원
CPSU-MANESS-S19S9G15
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
I am very grateful for your help,now I got it all figured out..I can do it own my own without necessary taking it to the Nokia center right here in Kenya. friday night funkin mods online
Britt Isaacs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 19
전체 시간: 2,750
