소개
This guide will help you replace the rear facing camera for the Nokia 6.
Be sure to take extra caution when removing anything from the motherboard.
필요한 것
Insert the SIM card ejection tool into the hole on the left side of the phone.
Remove the SIM card and microSD card.
Remove 18 screws.
There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
다른 2명이 해당 안내서를 완성하였습니다.
