주요 콘텐츠로 건너뛰기
Nokia 6010 Keypad Replacement
필요한 것
  1. Nokia 6010 Keypad Replacement, Battery: 1 단계, 이미지 1/3 Nokia 6010 Keypad Replacement, Battery: 1 단계, 이미지 2/3 Nokia 6010 Keypad Replacement, Battery: 1 단계, 이미지 3/3
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Nokia 6010 Keypad Replacement: 2 단계, 이미지 1/2 Nokia 6010 Keypad Replacement: 2 단계, 이미지 2/2
    • Lift the battery near the bottom and pry up.
  3. Nokia 6010 Keypad Replacement, SIM Card: 3 단계, 이미지 1/1
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  4. Nokia 6010 Keypad Replacement, Keypad: 4 단계, 이미지 1/2 Nokia 6010 Keypad Replacement, Keypad: 4 단계, 이미지 2/2
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  5. Nokia 6010 Keypad Replacement: 5 단계, 이미지 1/1
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nicholas Hanne
회원 가입일: 01/20/10
129 평판
안내서 8개 작성하였습니다
Cal Poly, Team 14-45, Regan Winter 2010 Cal Poly, Team 14-45, Regan Winter 2010 회원
CPSU-REGAN-W10S14G45
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 3,054
