주요 콘텐츠로 건너뛰기
Nokia 6061 Screen Replacement
필요한 것
  1. Nokia 6061 Screen Replacement, Screen: 1 단계, 이미지 1/3 Nokia 6061 Screen Replacement, Screen: 1 단계, 이미지 2/3 Nokia 6061 Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Gather the necessary tools:
    • T6 Torx screwdriver
    • Plastic opening tool
    • Small flathead screwdriver
  2. Nokia 6061 Screen Replacement: 2 단계, 이미지 1/1
    • This guide will show you how to replace the LCD—after it's been dropped one too many times.
  3. Nokia 6061 Screen Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    구매
    • Using a 2.0 flathead screwdriver, pry open and remove the black, plastic strip (beneath the screen) to reveal the 2 screws holding the screen in place.
  4. Nokia 6061 Screen Replacement: 4 단계, 이미지 1/1
    • Remove the two T6 Torx screws from the base of the display.
  5. Nokia 6061 Screen Replacement: 5 단계, 이미지 1/3 Nokia 6061 Screen Replacement: 5 단계, 이미지 2/3 Nokia 6061 Screen Replacement: 5 단계, 이미지 3/3
    • Once the screws are removed, flip the phone shut.
    • Insert the plastic opening tool at the position indicated and pry along the seam between the front cover and display.
    • Continue prying along the perimeter of the front cover until it is free from the phone.
  6. Nokia 6061 Screen Replacement: 6 단계, 이미지 1/2 Nokia 6061 Screen Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to pry the LCD circuit board up and out of the phone.
    • Be careful not to damage the circuit board.
    • Flip the display up and over to expose its ribbon cable connector.
  7. Nokia 6061 Screen Replacement: 7 단계, 이미지 1/3 Nokia 6061 Screen Replacement: 7 단계, 이미지 2/3 Nokia 6061 Screen Replacement: 7 단계, 이미지 3/3
    • Use a plastic opening tool to gently pry the LCD ribbon cable connector up out its socket on the LCD circuit board.
    • The other two photos show the male and female sides of the small green connector. Make sure they snap together tightly when the new display is attached.
  8. Nokia 6061 Screen Replacement: 8 단계, 이미지 1/1
    • To reassemble your phone, reattach the display to the phone by reconnecting the display ribbon cable. Place the screen assembly back into the front case of the phone.
  9. Nokia 6061 Screen Replacement: 9 단계, 이미지 1/1
    • Replace the phone cover by applying pressure until a click is heard.
  10. Nokia 6061 Screen Replacement: 10 단계, 이미지 1/1
    • With the cover reattached, flip the phone into the open position and replace the screws removed in step 3. The screw-holes are indicated in the photo.
    • Replace the black, plastic strip by applying pressure until the strip audibly clicks into place.
결승점
rosin7
회원 가입일: 02/14/13
55 평판
안내서 2개 작성하였습니다
Ohio State, Team 1-3, Buehl Spring 2013 Ohio State, Team 1-3, Buehl Spring 2013 회원
OSU-BUEHL-S13S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,061
