주요 콘텐츠로 건너뛰기
Nokia 6085h Keypad Replacement
필요한 것
  1. Nokia 6085h Keypad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the phone's battery.
  3. Nokia 6085h Keypad Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Nokia 6085h Keypad Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
  4. Nokia 6085h Keypad Replacement: 4 단계, 이미지 1개 중 1개
    • Gently pull off the hinge cap from the top of the phone by hand.
  5. Nokia 6085h Keypad Replacement: 5 단계, 이미지 1개 중 1개
    • Use a T6 Torx screwdriver to remove the four 7.6 mm screws at the corners of the battery compartment.
  6. Nokia 6085h Keypad Replacement: 6 단계, 이미지 2개 중 1개 Nokia 6085h Keypad Replacement: 6 단계, 이미지 2개 중 2개
    • Open the phone and turn it on its side. You will see a seam around the Nokia’s side.
    • Use the iFixit opening tool to run along this seam to pop the clips holding the casing to the frame.
  7. Nokia 6085h Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Use your hand to gently pull off the back panel from the bottom half of the phone.
  8. Nokia 6085h Keypad Replacement: 8 단계, 이미지 1개 중 1개
    • Close the phone and place it on a flat surface.
    • Use the plastic opening tool or your finger to lift up the motherboard from the bottom casing.
    • Be careful when pulling up the board; there is still a ribbon cable attached to the back of the board.
  9. Nokia 6085h Keypad Replacement: 9 단계, 이미지 1개 중 1개
    • Find the underside of the motherboard and locate the ribbon cable that attaches the board to the rest of the phone. Use the plastic opening tool to slowly detach the ribbon cable connector, then pull the motherboard away from the frame.
  10. Nokia 6085h Keypad Replacement, Keypad: 10 단계, 이미지 1개 중 1개
    • Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Andrew
회원 가입일: 10/04/10
397 평판
안내서 4개를 작성함
Cal Poly, Team 4-46, Amido Fall 2010 Cal Poly, Team 4-46, Amido Fall 2010 회원
CPSU-AMIDO-F10S4G46
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 2,357
