주요 콘텐츠로 건너뛰기
Nokia 6086 Battery Replacement
필요한 것
  1. Nokia 6086 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the phone.
    • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
    • Position the phone so that the back side is in view.
  2. Nokia 6086 Battery Replacement: 2 단계, 이미지 1/3 Nokia 6086 Battery Replacement: 2 단계, 이미지 2/3 Nokia 6086 Battery Replacement: 2 단계, 이미지 3/3
    • Remove the back battery cover.
    • Apply pressure on the cover while simultaneously sliding the cover downward.
  3. Nokia 6086 Battery Replacement: 3 단계, 이미지 1/3 Nokia 6086 Battery Replacement: 3 단계, 이미지 2/3 Nokia 6086 Battery Replacement: 3 단계, 이미지 3/3
    • Insert the iPod opening tool between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • The battery lifts out of the phone fast and easily.
    • Carefully lift the battery out of the phone.
결론
Andrea
회원 가입일: 04/15/10
70 평판
안내서 5개 작성하였습니다
Cal Poly, Team 26-30, Regan Spring 2010 Cal Poly, Team 26-30, Regan Spring 2010 회원
CPSU-REGAN-S10S26G30
4 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 3,832
