주요 콘텐츠로 건너뛰기
Nokia 6102i Inside Display Screen Replacement
필요한 것
  1. Nokia 6102i Inside Display Screen Replacement, Inside Display Screen: 1 단계, 이미지 1/2 Nokia 6102i Inside Display Screen Replacement, Inside Display Screen: 1 단계, 이미지 2/2
    • This step does not require much force.
    • With the screen facing up, connect the display connector to the smaller of the open connectors on the motherboard.
  2. Nokia 6102i Inside Display Screen Replacement: 2 단계, 이미지 1/2 Nokia 6102i Inside Display Screen Replacement: 2 단계, 이미지 2/2
    • Place the metal case over the top of the screen so that it snaps into place.
  3. Nokia 6102i Inside Display Screen Replacement: 3 단계, 이미지 1/3 Nokia 6102i Inside Display Screen Replacement: 3 단계, 이미지 2/3 Nokia 6102i Inside Display Screen Replacement: 3 단계, 이미지 3/3
    • Insert the circuitboard into the back of the phone, with the inside screen facing down.
    • Lightly press down on the left hand corner so the circuitboard attaches to the phone.
  4. Nokia 6102i Inside Display Screen Replacement, Cover: 4 단계, 이미지 1/3 Nokia 6102i Inside Display Screen Replacement, Cover: 4 단계, 이미지 2/3 Nokia 6102i Inside Display Screen Replacement, Cover: 4 단계, 이미지 3/3
    • Snap the top cover into place so that the outside screen is visible. Press around the perimeter to secure the case.
  5. Nokia 6102i Inside Display Screen Replacement: 5 단계, 이미지 1/2 Nokia 6102i Inside Display Screen Replacement: 5 단계, 이미지 2/2
    • Open the phone and insert the screws tightly.
  6. Nokia 6102i Inside Display Screen Replacement: 6 단계, 이미지 1/2 Nokia 6102i Inside Display Screen Replacement: 6 단계, 이미지 2/2
    • Snap on the black piece over the exposed screws.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Danielle
회원 가입일: 09/27/12
1 평판
안내서 1개 작성함
Ohio State, Team 1-3, Buehl Fall 2012 Ohio State, Team 1-3, Buehl Fall 2012 회원
OSU-BUEHL-F12S1G3
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 543
