주요 콘텐츠로 건너뛰기
Nokia 6102i Outside Display Screen Replacement
필요한 것
  1. Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: 1 단계, 이미지 1/3 Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: 1 단계, 이미지 2/3 Nokia 6102i Outside Display Screen Replacement, Remove Inside Display Screen: 1 단계, 이미지 3/3
    • This step does not require much force.
    • Use the plastic opening tool to pry between the seam of the black phone cover which is located at the base of the screen.
  2. Nokia 6102i Outside Display Screen Replacement, Remove Phone Case Screws.: 2 단계, 이미지 1/2 Nokia 6102i Outside Display Screen Replacement, Remove Phone Case Screws.: 2 단계, 이미지 2/2
    • Have a container ready to keep track of small parts.
    • Use the t6 screwdriver to remove the two visible screws that are immediately below the screen.
  3. Nokia 6102i Outside Display Screen Replacement, Remove silver and black phone case: 3 단계, 이미지 1/2 Nokia 6102i Outside Display Screen Replacement, Remove silver and black phone case: 3 단계, 이미지 2/2
    • Keep the phone closed, and slide the Ipod tool between the the silver and black phone case. Use the tool to slide all the way around the case to release the catches.
  4. Nokia 6102i Outside Display Screen Replacement, Unplug and Remove Circuit Board: 4 단계, 이미지 1/2 Nokia 6102i Outside Display Screen Replacement, Unplug and Remove Circuit Board: 4 단계, 이미지 2/2
    • Pull out the circuit board, which will remove it completely from the case
  5. Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: 5 단계, 이미지 1/3 Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: 5 단계, 이미지 2/3 Nokia 6102i Outside Display Screen Replacement, Remove Display Screen: 5 단계, 이미지 3/3
    • If the metal case is not already free, simultaneously release the metal tabs on both sides of the metal casing to remove the display screen.
  6. Nokia 6102i Outside Display Screen Replacement, Disconnect Interior Display Screen from circuit board.: 6 단계, 이미지 1/2 Nokia 6102i Outside Display Screen Replacement, Disconnect Interior Display Screen from circuit board.: 6 단계, 이미지 2/2
    • Be gentle when pulling off the display screen. If pulled too hard, the orange connecting ribbon will rip.
    • Lift off the display screen and disconnect it from the circuit board.
결론
Jonathan Brophy
회원 가입일: 04/14/10
1 평판
안내서 3개 작성하였습니다
Cal Poly, Team 23-78, Johann Spring 2010 Cal Poly, Team 23-78, Johann Spring 2010 회원
CPSU-JOHANN-S10S23G78
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 2,704
