이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
Note: Images on the right side may be hovered over to reveal larger versions.
이 단계에 사용된 도구:T6 Torx Screwdriver$9.99-
Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
Use a plastic opening tool to remove the silver cover over the antenna.
Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
Disconnect the logic board from the small orange chip.
다른 2명이 해당 안내서를 완성하였습니다.
