소개
Below is a list of instructions on replacing and cleaning a Nokia 6133 keypad.
필요한 것
Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
Lift off back cover.
Unscrew two T5 torx screws easily visible on the back side of the cell phone
Screws: 7.8mm
Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
Gently pull the phone apart and the flexible wire should detach from its connection as shown.
If not, lift up on the black tab within the left box in the picture.
With the front half of the phone, push the keypad towards the removed portion of the phone.
To clean, use a damp cloth with water.
다른 한 분이 해당 안내서를 완성하였습니다.
