주요 콘텐츠로 건너뛰기
Nokia 6133 Logic Board Replacement
필요한 것
  1. Nokia 6133 Logic Board Replacement, Battery: 1 단계, 이미지 1/2 Nokia 6133 Logic Board Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover of your cell phone by applying slight pressure with your thumb and pushing up towards the top of the phone.
    • Lift off back cover.
  2. Nokia 6133 Logic Board Replacement: 2 단계, 이미지 1/3 Nokia 6133 Logic Board Replacement: 2 단계, 이미지 2/3 Nokia 6133 Logic Board Replacement: 2 단계, 이미지 3/3
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove battery from cell phone.
  3. Nokia 6133 Logic Board Replacement, Keypad: 3 단계, 이미지 1/2 Nokia 6133 Logic Board Replacement, Keypad: 3 단계, 이미지 2/2
    • Unscrew two T5 torx screws easily visible on the back side of the cell phone
    • Screws: 7.8mm
    • Once screw are removed, the phone will separate easily into two pieces connected by a flexible wire strip.
    • Be sure to not lose or disconnect the indicated piece that the screw mounts to. It is spring loaded and is very dificult to reattach.
  4. Nokia 6133 Logic Board Replacement: 4 단계, 이미지 1/3 Nokia 6133 Logic Board Replacement: 4 단계, 이미지 2/3 Nokia 6133 Logic Board Replacement: 4 단계, 이미지 3/3
    • Use an iPod opening tool to gently pry open the back case as indicated in the picture.
    • Work your way down the side of the phone starting from the top down to the bottom. (Use multiple prying tools if necessary)
    • REPEAT on both sides, and be careful not to stab the circuitry with the tools.
  5. Nokia 6133 Logic Board Replacement: 5 단계, 이미지 1/3 Nokia 6133 Logic Board Replacement: 5 단계, 이미지 2/3 Nokia 6133 Logic Board Replacement: 5 단계, 이미지 3/3
    • Gently pull the phone apart and the flexible wire should detach from its connection as shown.
    • If not, lift up on the black tab within the left box in the picture.
    • With the front half of the phone, push the keypad towards the removed portion of the phone.
    • To clean, use a damp cloth with water.
  6. Nokia 6133 Logic Board Replacement, Logic Board: 6 단계, 이미지 1/1
    • Use a T6 Torx Screwdriver to remove the screw located in the bottom right corner of the back panel.
    • Screw: 6.4 mm
  7. Nokia 6133 Logic Board Replacement: 7 단계, 이미지 1/2 Nokia 6133 Logic Board Replacement: 7 단계, 이미지 2/2
    • Lift up from the top of the logic board as shown to remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Vincent Benvin
회원 가입일: 04/19/10
121 평판
안내서 4개 작성하였습니다
Cal Poly, Team 23-82, Johann Spring 2010 Cal Poly, Team 23-82, Johann Spring 2010 회원
CPSU-JOHANN-S10S23G82
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,777
