주요 콘텐츠로 건너뛰기
Nokia 6200 Classic Battery Replacement
  1. Nokia 6200 Classic Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the phone so it is face down (keypad side is down).
  2. Nokia 6200 Classic Battery Replacement: 2 단계, 이미지 1/3 Nokia 6200 Classic Battery Replacement: 2 단계, 이미지 2/3 Nokia 6200 Classic Battery Replacement: 2 단계, 이미지 3/3
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  3. Nokia 6200 Classic Battery Replacement: 3 단계, 이미지 1/3 Nokia 6200 Classic Battery Replacement: 3 단계, 이미지 2/3 Nokia 6200 Classic Battery Replacement: 3 단계, 이미지 3/3
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
결론
To replace the battery, simply put a new battery in the back of the phone, and replace the back cover.
Reid Polstra
회원 가입일: 10/22/12
1 평판
안내서 7개 작성하였습니다
Clemson, Team 15-5, Benson Fall 2012 Clemson, Team 15-5, Benson Fall 2012 회원
CLEM-BENSON-F12S15G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,133
