주요 콘텐츠로 건너뛰기
Nokia 6200 Classic Circuit Board Replacement
필요한 것
  1. Nokia 6200 Classic Circuit Board Replacement, Front Plate: 1 단계, 이미지 1/3 Nokia 6200 Classic Circuit Board Replacement, Front Plate: 1 단계, 이미지 2/3 Nokia 6200 Classic Circuit Board Replacement, Front Plate: 1 단계, 이미지 3/3
    • Pull up on both of the clips near the bottom of the phone as shown.
    • Lift off the front plate.
  2. Nokia 6200 Classic Circuit Board Replacement: 2 단계, 이미지 1/1
    • The keypad and LCD screen are revealed.
  3. Nokia 6200 Classic Circuit Board Replacement, Circuit Board: 3 단계, 이미지 1/2 Nokia 6200 Classic Circuit Board Replacement, Circuit Board: 3 단계, 이미지 2/2
    • Separate the keypad from the phone and place aside.
    • Wipe off any excess dust from where the keypad was attached to the phone.
  4. Nokia 6200 Classic Circuit Board Replacement: 4 단계, 이미지 1/2 Nokia 6200 Classic Circuit Board Replacement: 4 단계, 이미지 2/2
    • Remove the 6 - 7.9 mm screws highlighted by the markers using the T-6 head on the screwdriver.
  5. Nokia 6200 Classic Circuit Board Replacement: 5 단계, 이미지 1/2 Nokia 6200 Classic Circuit Board Replacement: 5 단계, 이미지 2/2
    • Separate the inside of the phone from the back of the phone.
  6. Nokia 6200 Classic Circuit Board Replacement: 6 단계, 이미지 1/2 Nokia 6200 Classic Circuit Board Replacement: 6 단계, 이미지 2/2
    • Gently pull apart the circuit board from the rest of the phone.
    • There is a small connector holding these two pieces together, so use caution when pulling apart so as not to damage it.
결론
To reattach the circuit board, line up the connector at the top of the board with the back of the LCD Screen attachment. Place the two boards together, and screw in the 6 screws.
Reid Polstra
회원 가입일: 10/22/12
1 평판
안내서 7개 작성하였습니다
Clemson, Team 15-5, Benson Fall 2012 Clemson, Team 15-5, Benson Fall 2012 회원
CLEM-BENSON-F12S15G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 767
