주요 콘텐츠로 건너뛰기
Nokia 6200 Classic Vibrator Replacement
필요한 것
  1. Nokia 6200 Classic Vibrator Replacement, Front Plate: 1 단계, 이미지 1/3 Nokia 6200 Classic Vibrator Replacement, Front Plate: 1 단계, 이미지 2/3 Nokia 6200 Classic Vibrator Replacement, Front Plate: 1 단계, 이미지 3/3
    • Pull up on both of the clips near the bottom of the phone as shown.
    • Lift off the front plate.
  2. Nokia 6200 Classic Vibrator Replacement: 2 단계, 이미지 1/1
    • The keypad and LCD screen are revealed.
  3. Nokia 6200 Classic Vibrator Replacement, Vibrator: 3 단계, 이미지 1/2 Nokia 6200 Classic Vibrator Replacement, Vibrator: 3 단계, 이미지 2/2
    • Separate the keypad from the phone and place aside.
    • Wipe off any excess dust from where the keypad was attached to the phone.
  4. Nokia 6200 Classic Vibrator Replacement: 4 단계, 이미지 1/2 Nokia 6200 Classic Vibrator Replacement: 4 단계, 이미지 2/2
    • Remove the six screws highlighted by the markers using the screwdriver.
  5. Nokia 6200 Classic Vibrator Replacement: 5 단계, 이미지 1/2 Nokia 6200 Classic Vibrator Replacement: 5 단계, 이미지 2/2
    • Separate the inside of the phone from the back of the phone.
  6. Nokia 6200 Classic Vibrator Replacement: 6 단계, 이미지 1/3 Nokia 6200 Classic Vibrator Replacement: 6 단계, 이미지 2/3 Nokia 6200 Classic Vibrator Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Locate vibration device on the bottom of the back cover.
    • Pull up on the vibration device using tweezers.
    • Remove the vibration device and place it aside.
결론
Reid Polstra
회원 가입일: 10/22/12
1 평판
안내서 7개 작성하였습니다
Clemson, Team 15-5, Benson Fall 2012 Clemson, Team 15-5, Benson Fall 2012 회원
CLEM-BENSON-F12S15G5
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 537
