주요 콘텐츠로 건너뛰기
Nokia 6236i SIM Card Replacement
  1. Nokia 6236i SIM Card Replacement, Battery: 1 단계, 이미지 1/2 Nokia 6236i SIM Card Replacement, Battery: 1 단계, 이미지 2/2
    • Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
    • Lift the battery case off of the phone.
  2. Nokia 6236i SIM Card Replacement: 2 단계, 이미지 1/3 Nokia 6236i SIM Card Replacement: 2 단계, 이미지 2/3 Nokia 6236i SIM Card Replacement: 2 단계, 이미지 3/3
    • Use your thumb to get underneath the battery and pull up and out from the bottom of the battery tray.
    • The battery should lift out with minimal resistance.
  3. Nokia 6236i SIM Card Replacement, SIM Card: 3 단계, 이미지 1/3 Nokia 6236i SIM Card Replacement, SIM Card: 3 단계, 이미지 2/3 Nokia 6236i SIM Card Replacement, SIM Card: 3 단계, 이미지 3/3
    • Once the battery is removed, pull the tab of the metal sim card cover, and lift it up.
    • The sim card is underneath and can now be removed.
결론
Jesse Roach
회원 가입일: 04/24/10
13 평판
안내서 1개 작성함
Cal Poly, Team 10-46, Garner Spring 2010 Cal Poly, Team 10-46, Garner Spring 2010 회원
CPSU-GARNER-S10S10G46
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 2,381
