주요 콘텐츠로 건너뛰기
소개
This guide is to instruct the reader about the steps on replacing the internal antenna. The phone will have to be disassembled to reach to the antenna. A proper set of Torx (Star) screw-driver is necessary to complete the procedures.
부품
지정된 부품이 없습니다.
  1. Press and hold the battery release button and slide the battery away from the Nokia logo Press and hold the battery release button and slide the battery away from the Nokia logo
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Slide the SIM card lock away from the SIM card. The SIM card pops out. Remove the SIM card. The SIM card pops out. Remove the SIM card.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Unscrew and remove the four T6 Torx screws.
    • Unscrew and remove the four T6 Torx screws.
  4. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Use the plastic opening tool to separate the top part of the backplate. The plastic clips at the top require slightly more force to separate. The plastic clips at the top require slightly more force to separate.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Remove the screw holding the antenna to the circuit board. Carefully lift off the antenna from the circuit board.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Wilson Tam
회원 가입일: 2010년 09월 29일
77 평판
안내서 1개 작성함
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 회원
CPSU-FORTE-F10S14G41
5 회원들
안내서 16개 작성하였습니다
댓글 2개
Thanks for a nice and helpful instruction.
The rubber power-on button had broken down so I just removed the damaged parts. Now using a toothpick to push the microswitch directly.
Only using the phone indoors for nostalgic reasons, playing Snake :-)
Brgrds Ove
ove.tandberg - 답글
Thanks for antenna help
I have had about three 6310i’s and the on/off button was the failure problem in all three.
Andrew Richards - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 7,715
