주요 콘텐츠로 건너뛰기
소개
This guide shows the procedures to replace a new keypad and clean metal button contacts for Nokia 6310i cell phone. Refer to the guides for removing the battery and separating the case from the motherboard.
부품
지정된 부품이 없습니다.
  1. Press and hold the battery release button and slide the battery away from the Nokia logo Press and hold the battery release button and slide the battery away from the Nokia logo
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Slide the SIM card lock away from the SIM card. The SIM card pops out. Remove the SIM card. The SIM card pops out. Remove the SIM card.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Unscrew and remove the four T6 Torx screws.
    • Unscrew and remove the four T6 Torx screws.
  4. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Use the plastic opening tool to separate the top part of the backplate. The plastic clips at the top require slightly more force to separate. The plastic clips at the top require slightly more force to separate.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Remove the screw holding the antenna to the circuit board. Carefully lift off the antenna from the circuit board.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  7. Lift off the motherboard from the faceplate.
    • Lift off the motherboard from the faceplate.
  8. Remove the plastic keypad from the faceplate. Remove the plastic keypad from the faceplate.
    • Remove the plastic keypad from the faceplate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ka Siu
회원 가입일: 2010년 09월 30일
69 평판
안내서 1개 작성함
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 회원
CPSU-FORTE-F10S14G41
5 회원들
안내서 16개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 5,323
