주요 콘텐츠로 건너뛰기
Nokia 6310i Speaker Replacement
필요한 것
  1. Nokia 6310i Speaker Replacement, Battery: 1 단계, 이미지 1/2 Nokia 6310i Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Nokia 6310i Speaker Replacement, SIM card: 2 단계, 이미지 1/3 Nokia 6310i Speaker Replacement, SIM card: 2 단계, 이미지 2/3 Nokia 6310i Speaker Replacement, SIM card: 2 단계, 이미지 3/3
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Nokia 6310i Speaker Replacement, Back Cover: 3 단계, 이미지 1/1
    • Unscrew and remove the four T6 Torx screws.
  4. Nokia 6310i Speaker Replacement: 4 단계, 이미지 1/3 Nokia 6310i Speaker Replacement: 4 단계, 이미지 2/3 Nokia 6310i Speaker Replacement: 4 단계, 이미지 3/3
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  5. Nokia 6310i Speaker Replacement: 5 단계, 이미지 1/3 Nokia 6310i Speaker Replacement: 5 단계, 이미지 2/3 Nokia 6310i Speaker Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  6. Nokia 6310i Speaker Replacement, Antenna: 6 단계, 이미지 1/2 Nokia 6310i Speaker Replacement, Antenna: 6 단계, 이미지 2/2
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  7. Nokia 6310i Speaker Replacement, Motherboard: 7 단계, 이미지 1/1
    • Lift off the motherboard from the faceplate.
  8. Nokia 6310i Speaker Replacement, Speaker: 8 단계, 이미지 1/2 Nokia 6310i Speaker Replacement, Speaker: 8 단계, 이미지 2/2
    • Gently pop out the golden spring in the middle of the speaker. It should come out with little force.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mustafa
회원 가입일: 09/23/10
156 평판
안내서 4개 작성하였습니다
Cal Poly, Team 14-41, Forte Fall 2010 Cal Poly, Team 14-41, Forte Fall 2010 회원
CPSU-FORTE-F10S14G41
5 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 5,134
