이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press and hold the battery release button and slide the battery away from the Nokia logo
Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
Use the plastic opening tool to separate the top part of the backplate.
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
Gently pop out the golden spring in the middle of the speaker. It should come out with little force.
다른 2명이 해당 안내서를 완성하였습니다.
