주요 콘텐츠로 건너뛰기
Nokia 6350-1b Battery Replacement
필요한 것
  1. Nokia 6350-1b Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the back cover of the phone by sliding it downwards.
    • This will be a thin panel that has three stripes to provide better grip.
  2. Nokia 6350-1b Battery Replacement: 2 단계, 이미지 1/1
    • Caution: When you slide the panel downwards, it will immediately come loose.
    • Remove the BP-6MT battery. There should be an indent showing where you will lift.
  3. Nokia 6350-1b Battery Replacement: 3 단계, 이미지 1/1
    • Once you have removed the old battery, you can begin to install the new battery.
    • Line up the gold indentations in the upper left corner of the battery with the three gold indentations in the upper left hand corner of the empty battery space.
  4. Nokia 6350-1b Battery Replacement: 4 단계, 이미지 1/1
    • Ensure that when you have lined up the battery, you are able to seamlessly insert into phone.
    • Note: If it does not slide seamlessly, it is not being inserted correctly
  5. Nokia 6350-1b Battery Replacement: 5 단계, 이미지 1/1
    • After the battery has clicked in, you need to reinstall the back panel of the phone.
    • Line the back panel up with the phone.
  6. Nokia 6350-1b Battery Replacement: 6 단계, 이미지 1/1
    • Line up the back panel starting from the bottom.
    • Once lined and pressed down, slide upward. You should be able to feel and hear it click back into place.
결론
Anna
회원 가입일: 04/13/12
21 평판
안내서 2개 작성하였습니다
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 회원
SUNYCORT-GETTO-S12S1G2
2 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 1,337
