주요 콘텐츠로 건너뛰기
Nokia 6350-1b Display Screen Replacement
필요한 것
  1. Nokia 6350-1b Display Screen Replacement, Display Screen: 1 단계, 이미지 1/2 Nokia 6350-1b Display Screen Replacement, Display Screen: 1 단계, 이미지 2/2
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move the plastic pry along the frame unlocking all of the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry too hard, doing so could crack the plastic frame.
  2. Nokia 6350-1b Display Screen Replacement: 2 단계, 이미지 1/1
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move along this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Display Screen Replacement: 3 단계, 이미지 1/1
    • Disconnect the flex cable from the logic board.
    • Disconnect the LCD display screen.
    • Remove the LCD display screen from the rest of the device.
  4. Nokia 6350-1b Display Screen Replacement: 4 단계, 이미지 1/1
    • Connect the new LCD display screen to the phone.
    • Reconnect the Logic Board to the flex cable.
  5. Nokia 6350-1b Display Screen Replacement: 5 단계, 이미지 1/1
    • Using the T-5 screwdriver, screw the four screws back into the phone.
  6. Nokia 6350-1b Display Screen Replacement: 6 단계, 이미지 1/1
    • Place the cover back on the device so that it is in the correct position to be reinstalled.
    • Press gently on the cover so that it snaps back into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anna
회원 가입일: 04/13/12
21 평판
안내서 2개 작성하였습니다
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 회원
SUNYCORT-GETTO-S12S1G2
2 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hi
Thanks for putting these together. I have a flip phone 6350 and I love it. Every time one stops functioning I get another one used. But I often have problems with the charging ports. The connection gets wonky and only works when I move the plug around in the socket of the phone. Can these be easily replaced? fixed? I even tried using a universal charger and charged the batteries in that, but then the battery connections stopped working.
thanks!
Annemarie
Annemarie Heineman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 13
전체 시간: 1,850
