주요 콘텐츠로 건너뛰기
Nokia 6350-1b Logic board Replacement
필요한 것
  1. Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: 1 단계, 이미지 1/2 Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: 1 단계, 이미지 2/2
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move it along the frame unlocking the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry to hard and crack the plastic frame.
  2. Nokia 6350-1b Logic board Replacement, Removing the screen cover: 2 단계, 이미지 1/3 Nokia 6350-1b Logic board Replacement, Removing the screen cover: 2 단계, 이미지 2/3 Nokia 6350-1b Logic board Replacement, Removing the screen cover: 2 단계, 이미지 3/3
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move alone this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Logic board Replacement, Removing broken logic board: 3 단계, 이미지 1/3 Nokia 6350-1b Logic board Replacement, Removing broken logic board: 3 단계, 이미지 2/3 Nokia 6350-1b Logic board Replacement, Removing broken logic board: 3 단계, 이미지 3/3
    • Disconnect the flex cable from the logic board.
    • Disconnect the camera from the logic board.
    • Disconnect the LCD display screen.
    • Disconnect the LCD phone screen.
    • Carefully remove the broken logic board by freeing it from the various locks holding it in place.
    • Be careful not to touch either of the screens. You can leave finger prints and damage the screens.
  4. Nokia 6350-1b Logic board Replacement, Replacing Logic Board: 4 단계, 이미지 1/2 Nokia 6350-1b Logic board Replacement, Replacing Logic Board: 4 단계, 이미지 2/2
    • Take the new logic board and connect all the parts you just disconnected to their correct locations.
  5. Nokia 6350-1b Logic board Replacement: 5 단계, 이미지 1/2 Nokia 6350-1b Logic board Replacement: 5 단계, 이미지 2/2
    • Place the cover so that it is in the correct position to be re-installed.
    • Press gently on the cover so that it snaps back into place.
결론
Adrianna
회원 가입일: 04/18/12
35 평판
안내서 2개 작성하였습니다
SUNY Cortland, Team 1-2, Getto Spring 2012 SUNY Cortland, Team 1-2, Getto Spring 2012 회원
SUNYCORT-GETTO-S12S1G2
2 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,547
