주요 콘텐츠로 건너뛰기
Nokia 6560 keypad replacement or cleaning
필요한 것
  1. Nokia 6560 keypad replacement or cleaning, Battery: 1 단계, 이미지 1/2 Nokia 6560 keypad replacement or cleaning, Battery: 1 단계, 이미지 2/2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 keypad replacement or cleaning: 2 단계, 이미지 1/2 Nokia 6560 keypad replacement or cleaning: 2 단계, 이미지 2/2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 keypad replacement or cleaning, Keypad: 3 단계, 이미지 1/2 Nokia 6560 keypad replacement or cleaning, Keypad: 3 단계, 이미지 2/2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 keypad replacement or cleaning: 4 단계, 이미지 1/2 Nokia 6560 keypad replacement or cleaning: 4 단계, 이미지 2/2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tim Bergmann
회원 가입일: 01/18/10
35 평판
안내서 4개 작성하였습니다
Cal Poly, Team 3-17, Maness Winter 2010 Cal Poly, Team 3-17, Maness Winter 2010 회원
CPSU-MANESS-W10S3G17
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 2,201
