주요 콘텐츠로 건너뛰기
Nokia 6590i Battery Charger Connector Replacement
필요한 것
  1. Nokia 6590i Battery Charger Connector Replacement, Battery: 1 단계, 이미지 1/2 Nokia 6590i Battery Charger Connector Replacement, Battery: 1 단계, 이미지 2/2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Battery Charger Connector Replacement: 2 단계, 이미지 1/1
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Battery Charger Connector Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: 3 단계, 이미지 1/1
    • Grip the front cover from the bottom.
  4. Nokia 6590i Battery Charger Connector Replacement: 4 단계, 이미지 1/1
    • Lift the front cover off.
  5. Nokia 6590i Battery Charger Connector Replacement: 5 단계, 이미지 1/1
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Battery Charger Connector Replacement: 6 단계, 이미지 1/1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Battery Charger Connector Replacement: 7 단계, 이미지 1/1
    • Remove assembly from phone
  8. Nokia 6590i Battery Charger Connector Replacement, Logic Board: 8 단계, 이미지 1/1
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Battery Charger Connector Replacement: 9 단계, 이미지 1/1
    • Lift the logic board out of the phone.
  10. Nokia 6590i Battery Charger Connector Replacement, Battery Charger Connector: 10 단계, 이미지 1/1
    • Locate battery charger connector
  11. Nokia 6590i Battery Charger Connector Replacement: 11 단계, 이미지 1/1
    • Grasp top and bottom of battery charger connector on the left side
  12. Nokia 6590i Battery Charger Connector Replacement: 12 단계, 이미지 1/1
    • Lift out the battery charger connector
결론
Colby Leslie
회원 가입일: 10/05/10
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 22-3, Maness Fall 2010 Cal Poly, Team 22-3, Maness Fall 2010 회원
CPSU-MANESS-F10S22G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 1,867
