주요 콘텐츠로 건너뛰기
Nokia 8260 Keypad Replacement
필요한 것
  1. Nokia 8260 Keypad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the cell phone.
  2. Nokia 8260 Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Keypad Replacement: 3 단계, 이미지 1개 중 1개
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Keypad Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back cover.
  5. Nokia 8260 Keypad Replacement: 5 단계, 이미지 1개 중 1개
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Keypad Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Keypad Replacement, Antenna: 7 단계, 이미지 1개 중 1개
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Keypad Replacement: 8 단계, 이미지 1개 중 1개
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Keypad Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the antenna door.
  10. Nokia 8260 Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 Keypad Replacement, Circuit Board: 11 단계, 이미지 1개 중 1개
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 Keypad Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the back covering.
  13. Nokia 8260 Keypad Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the two screws at the top.
  14. Nokia 8260 Keypad Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  15. Nokia 8260 Keypad Replacement, Keypad: 15 단계, 이미지 1개 중 1개
    • Remove the plastic border lying on the keypad.
  16. Nokia 8260 Keypad Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
결론
작성자
3다른 기여자 명과 함께
Aaron Jen
회원 가입일: 04/11/10
1 평판
안내서 7개를 작성함
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G94
4 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 15,963
