주요 콘텐츠로 건너뛰기
Nokia 8260 Speaker Replacement
필요한 것
  1. Nokia 8260 Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the cell phone.
  2. Nokia 8260 Speaker Replacement: 2 단계, 이미지 1/1
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Speaker Replacement: 3 단계, 이미지 1/1
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the back cover.
  5. Nokia 8260 Speaker Replacement: 5 단계, 이미지 1/1
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Speaker Replacement: 6 단계, 이미지 1/1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Speaker Replacement, Antenna: 7 단계, 이미지 1/1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Speaker Replacement: 8 단계, 이미지 1/1
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Speaker Replacement: 9 단계, 이미지 1/1
    • Remove the antenna door.
  10. Nokia 8260 Speaker Replacement: 10 단계, 이미지 1/1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 Speaker Replacement, Circuit Board: 11 단계, 이미지 1/1
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 Speaker Replacement: 12 단계, 이미지 1/1
    • Remove the back covering.
  13. Nokia 8260 Speaker Replacement: 13 단계, 이미지 1/1
    • Remove the two screws at the top.
  14. Nokia 8260 Speaker Replacement: 14 단계, 이미지 1/1
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  15. Nokia 8260 Speaker Replacement, Speaker: 15 단계, 이미지 1/1
    • Remove the speaker.
결론
Aaron Jen
회원 가입일: 04/11/10
1 평판
안내서 7개 작성하였습니다
Cal Poly, Team 27-94, Amido Spring 2010 Cal Poly, Team 27-94, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G94
4 회원들
안내서 14개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,982
