주요 콘텐츠로 건너뛰기
Nokia 8265 Display Screen/Keyboard Replacement
필요한 것
  1. Nokia 8265 Display Screen/Keyboard Replacement, Display Screen/Keyboard: 1 단계, 이미지 1개 중 1개
    • Start by removing the face plate of the phone with a plastic tool.
    • Once plastic tool is wedged into the side of the phone, twist and leverage the face plate off.
  2. Nokia 8265 Display Screen/Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Once the face plate is off, you will have exposed the keypad.
  3. Nokia 8265 Display Screen/Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Simply remove the keypad from on top of the phone, and place it off to the side, leaving just the phone itself remaining
  4. Nokia 8265 Display Screen/Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Taking a very small screwdriver, carefully unscrew the six screws attaching the top layer of the screen from the body of the phone.
    • Make sure to remember what screw goes where.
  5. Nokia 8265 Display Screen/Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Once the six screws are removed, you may take off the screen section of the phone, exposing the inner workings of the cell phone.
  6. Nokia 8265 Display Screen/Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Now you have successfully removed the display screen and keyboard.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Jack
회원 가입일: 04/20/12
1 평판
안내서 4개를 작성함
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 회원
SUNYCORT-GETTO-S12S1G1
2 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 52
전체 시간: 1,073
