주요 콘텐츠로 건너뛰기
Nokia 8265 Keypad Replacement
필요한 것
  1. Nokia 8265 Keypad Replacement, Keypad: 1 단계, 이미지 1/1
    • Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
    • To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
  2. Nokia 8265 Keypad Replacement: 2 단계, 이미지 1/1
    • Once popped off, remove the faceplate entirely, exposing the keypad.
  3. Nokia 8265 Keypad Replacement: 3 단계, 이미지 1/1
    • You can pick up the keypad with ease, as it is not attached to the phone itself.
  4. Nokia 8265 Keypad Replacement: 4 단계, 이미지 1/1
    • To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
결론
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
Jack
회원 가입일: 04/20/12
1 평판
안내서 4개 작성하였습니다
SUNY Cortland, Team 1-1, Getto Spring 2012 SUNY Cortland, Team 1-1, Getto Spring 2012 회원
SUNYCORT-GETTO-S12S1G1
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 14
전체 시간: 816
